Removing sealer from saltillo tile
Old 05-30-00, 10:06 AM
Guest
Post
Does anyone know how to successfully strip a waterbased sealer from Saltillo Tile? My contractor really messed up the tile but I think it can be fixed if the sealer was removed and re-done.
Old 05-30-00, 10:38 PM
Guest
Post
All saltillo tile must be sealed before it is installed. Two coats must be applied to the top surface only. All sealers soak into this type of tile.Unfortunatly the damage is done. Your grout color has stained your tile.You might try a high gloss finall sealer, sometimes this can change the tint of the tile and grout to an exeptable level. Good luck.
