Tiling over tile
Old 07-19-05, 11:48 PM
kemar51
Tiling over tile
I have a shower with dated 4 in. square tile. The tile is solid.I would like to change to a white 6 in. square tile. Can I tile over the existing tile and if so, what prep work must be done? Thanks for any help you can give.
Old 07-20-05, 01:46 PM
T
If the olsd substrate behind them is drywall, now is a good time to just redo it.
If old mud walls and solid, no cracks, loose grout or sealers, use a good modified thinset, you might have to deal with the thicker edges where they end on the old tile.
