tile above a tub surround and ceiling
Old 06-30-00, 11:51 AM
Question
I would like to put ceramic tile above the tub surround and also on the ceiling above it. The walls are blueboard, skim coat plaster, sealed and painted with latex paint. What prep work needs to be done to the surface before using the mastic? Thank you for your help. D.
Old 07-12-00, 08:43 PM
Post
Install some 1/4 inch wonder board then tile over that.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by dlc:
I would like to put ceramic tile above the tub surround and also on the ceiling above it. The walls are blueboard, skim coat plaster, sealed and painted with latex paint. What prep work needs to be done to the surface before using the mastic? Thank you for your help. D.<HR></BLOCKQUOTE>
