Grouting Question
Grouting Question
What type of grout is recommended on kitchen countertops and backsplash?
I have heard of epoxy but don't know the difference and where to buy it at
MJCAM
MJCAM
Unless you worked with epoxy in the past, stick with traditional cement based grouts, if you really want epoxy Laticretes Spectrolock is more user friendly and sold at Lowes, still epoxy though.
What type of tile and joint sizes do you have, counter and backsplash?, this would help.
It is glazed ceramic tile with joints 1/8.
Now I also used a ceramic tile adhesive, but I heard thinset is better. Should I continue using the adhesive or stop and switch to thinset?
Also, sorry for all the questions but what kind of sealer is recommended after grouting and should I still use regular grout instead of epoxy?
MJCAM
MJCAM
I wouldn't use the adhesive on the countertop and depending on size of tile on the backsplash, whether I would use it there, what type of adhesive is this?
Use regular grout, if 1/8" joints, it's up to you which one, sanded or unsanded, both will work, the unsanded will give you a smoother finish, sanded a rougher look.
Aquamix Gold 15 from HD is a good sealer.
It is called Acrylic-Pro Ceramic Tile Adhesive type1, some guy from HD recommended this but you never know if you should take there advice so I've
heard. What type of adhesive do you recommend for tiling both coutertops and backsplash? You seem to know alot about this sort of stuff
MJCAM
MJCAM
You can use the mastic on the backsplash if you like, if the tile is 8x8 or smaller and ceramic, not stone.
For the countertop tile, use a modified thinset you mix with water, Versabond will work fine and sold at HD also.
How is the countertop constructed?
