grout additive?
Old 07-27-05, 09:34 AM
irod
Question grout additive?
help me - do we use sanded or non, do we need a grout additive and what size spacers do we use?? also hd guy says not necessary to tape up backer joints? and one guy says use rino board in place or backer?
we have 12x12 6x12 and 6x6 porcelin tile for kitchen/dining laying the random pattern.
please help
Old 07-27-05, 05:27 PM
Tileguybob's Avatar
Use sanded grout if the joint is bigger than 1/8", use unsanded for 1/8" and smaller.
The additive can be used if the directions on the bag of grout say it can, some grouts can only be mixed with water, putting the additive in changes the chemical balance. The additive is good because it keeps the color more uniform and stays closer to the color they advertise it to be. Be careful because it dries fast so dont get ahead of yourself when spreading the grout or it will be harder to clean up.
Tape the seams of the cement board with mesh tape. You can do this as you set the tile. Cover the tape with modified thinset so it gets pushed down through the tape and into the 1/8" gap you will leave between boards.
Old 07-27-05, 06:52 PM
irod
Question
do you use the same stuff under the backer boards- the guy at home depot sai d use cheap under boards and good stuff on top when you set tile. also what is this leveler stuff and how do you know if you need it? :confused
Old 07-27-05, 08:13 PM
Tileguybob's Avatar
Yes, you can use the cheap, unmodified stuff under the cement board, it is there to fill gaps and voids, not to bond, the nails/screws take care of that.
Self Leveling Cement (SLC) is used after the cement board goes down, if you have a dip in the floor that you want to fix before the tile goes in. When mixed with water it pours out on the floor like pancake batter on the griddle, goes down smooth and flat. Why do you ask, do you think you need it? There is more to know about using it.
Old 07-28-05, 08:00 AM
irod
not sure what I need really- just trying to find out all that I can- do my research before Friday-- we had a tile layer lined up but did not work out, next guy never returns phone calls- both are too busy so now we are doing it ourselves and have no real experience in tile. I think the floor is ok- has subfloor and 3/4 underlayment- house is only 15 years old but did not know.was not real sure how you know. also trying to figure out best way to cut door frames
Old 07-29-05, 06:32 AM
F
Beg, borrow, steal, or buy a jamb saw for about $12. Determine where you want to cut, and lay a correct thickness board in the doorway (to guide and keep the saw level) and cut off the jamb.
Old 07-29-05, 07:47 AM
irod
Talking
thanks for all the help- wish us luck and straight lines
