I found that a masonary chisel (also called a "cold" chisel) and hammer works well to remove mosaic tile from concrete. Hold the chisel at the base of the tile and smack it with a hammer. Wear eye protection.
I removed some wall tile to make a plumbing repair and now i would like to reuse the tile but it was put on with thin set can any one tell me how to remove the thin set from the back of the tiles
I currently have a 3/4" subfloor that is pretty solid. The local mega home improvement dude tells me I could use 1/4" Hardibacker on top of that and my serface would be sufficient. Is this advise correct?
Please let me know what experice you have if you reply to this.
