Bad tile = grout sticking to tile
Old 11-22-00, 07:10 AM
Guest
Question
Not being leary of the "Special" price on the tile I bought I now know why!! I have come to the conclusion that the special was due to the lack of enough glaze on the tile. After grouting I found that the grout was sticking to the tiles, mainly in the stone type vein/pattern. Scrubbing them out was the only way of getting the grout removed. But, I could not get to all of them before they completely dried.
Does anyone know of an easy way to get the grout removed from my less than perfect glazed tiles? With out taking off the glaze? Thanks for the help.
Old 11-22-00, 06:05 PM
Guest
Post
Hey Jones,
Tiles with depressions in them seem to be popular these days. We've run into quite a few otherwise fine tiles that are impossible to clean. I try to steer away from them, but this isn't what you're after.
Unfortunately, if there are serious grout deposits remaining in the depressions, there is no practical way to remove them. Light grout residue is normally removed with acid, but the concentration needed to remove actual grout would probably destroy the glaze on the tiles.
I am sorry to be the bearer of such sad tidings, and I sincerely hope someone else will come along and say I'm full of it, but I think I'm right.
John
http://www.johnbridge.com
Old 11-23-00, 01:56 AM
Guest
Lightbulb
Hey Jones;
John is right acid wil probably destroy your tile and you would not be happy. You can try this but, it is not going to be easy. Get either a small dowel and do each one individually by rubbing the heavy grout off or try a brass brush (about toothbrush sized) (please try the brush in an inconspicuous area first to see that it does not mar the tile ) Other than doing each tile individually like that, I have no Idea what to recommend. I hope it works for you!
Regards,
Rich Gately (Tileman1) www.gatelytilecompany.homestead.com
Old 12-04-00, 03:13 PM
Guest
Smile grout in tile
Saw your question and possibly have an answer. I bought expensive tiles that had crevices in them and grout stuck in the crevices. Very hard to remove. I called in the installer and he came over with WD 40. He spread it on and wiped it clean with a cotton cloth. It worked! (at least so far - 1 week later). It can be a little slippery. Just wipe it a lot. \good luck.
