Tile over plywood?
Tile over plywood?
Can tile be installed over plywood (external grade)? Or does it have to be set on backerboard?
Originally Posted by Tileguybob
No, he means like what size joists, spacing and unsupported span and how thick is the plywood there now?
There are no joists.
Oh, so you have a concrete slab and you want to raise the final floor height 1.5" over what it is now, is that correct?
How about a mud floor base and set the tile on it with thinset. There is no way to screw plywood down onto a concrete slab, at least not in any way that would support tile. You would need some wood slats put in first as sleepers but they would have to be thick enough to hold the screw that is used to hold down the plywood so I think your overall floor height would exceed the 1.5" you are shooting for.
If Tileman sees this post he will have some good ideas maybe. He is very good on cement floor issues like this. (Did I just put the pressure on you or what?
No pressure, MK, Tileguybob said it exactly, sleeper system or Mud job, mud is the way to go, you could also use self leveling compounds, but that would be VERY expensive.
NO, you can noy install plywood or any backerboard over concrete directly for tiling.
