About to tile the bathroom floor, am I missing anything?
Hey, This is my first gut and replace of a bathroom, so I just wanted to run it by all of you.
5 1/2' x 8' Bathroom (pic)
http://www.tamogila.com/images/renov...m/P1010127.jpg
Big old 2"x8"'s 16" OC - 14' partially supported span (there is a wall that runs directly under the bathroom, and it looks pretty heavy duty but I don't know if is't really supporting the joists). Two of the joists need repair. (pic) http://www.tamogila.com/images/renov...m/P1010121.jpg
I have all of the plumbing removed and have ripped up the failing 3/4" T&G and am ready to start laying the subfloor. These are the steps I want to take:
1. Lay down 3/4" Ext Ply - screwed to the joists.
2. Thinset
3. 1/4" cement board - screwed to Ply, but not joists.
--> Get plumber to rough in plumbing
4. Thinset
5. Tile
6. Grout
Please let me know if I'm on the right track, and let me know if I missed something.
Thanks!
2. Thinset
4. Thinset
5. Tile
6. Grout
Thanks!
Originally Posted by Tileman
I usually mud all my bathroom jobs if the height isn't a problem, mud can go over 1 layer of whatever is there, usually.
A mud job is 1 1/4" minimum thickness of 1 part portland cement to 4 parts mason sand, mixed with water till it just holds together in a ball, then it placed and packed over tar paper and wire lath and leveled, this is all over 3/4" subfloor, sheet or plank flooring.
