ceramic tile on cement deck
Help Please,I recently poured a cement addition to my porch total size is 16.5 by 11.25 ft. I want to cover it with ceramic tile any suggestions would be appreciated or any possible problems that I could run in to. Any help or advice would be appreciated because I'm not very handy. Thanks Willie
First you'll have to wait 28 days for it to cure, unless you use a membrane called Ditra.
Is the slab pitched for water runoff, is it flat, exposed to the elements, is this freeze thaw region?
