does stain proof grout really work?
I saw a stain proof grout by Traffic master at Home Depot -- has anyone used it? Does it last as long as regular grout? And stay clean -- what if you ever have to remove it? Please help, anyone who has had experience with it. Thanks
I have not used it and on other tile forums I have heard some general complaints about it. I cant remeber the specifics however. The consensus seems to be that the SpectraLoc Pro grout from Laticrete is a good one. It is sold at tile stores that carry the Laticrete line as well as Lowes. It is an epoxy based grout but very user friendly as long as you closely follow the directions. The next best thing would be to use a grout that can be mixed with latex additive rather than water as this improves the density and hardness of the grout as well as giving it more uniform color throughout. It's not stainproof but even blueberry or tomato sauce wont penetrate if you wipe it up quickly.
We used the Trafficmaster stuff from Home Depot (at the home owners request). It was the worst grouting experience of my life. It was basically mastic with a little sand in it. I could only grout about three square feet before I had to wash. Then it shrunk as it dried to I ended up having to grout over it three times to get it to look good. (you can however grout over it without any problems)
Would I recommend it? NO! Not even to an enemy.
Follow Tileguybob's suggestions. In my experience epoxy grouts aren't as easy to work with. The grout mixed with additive would be the most DIY'er friendly in my opinion.
Later
Bryan
Later
Bryan
Forget the pre-mixed stuff, it's garbage.
Unless you have worked with epoxy, just use a cementbased modified grout and seal it a week after grouting.
If you want epoxy, Spectrolock pro is user friendly.
