Is there a reason not to use wire mesh for backing.
Old 10-23-05, 02:30 PM
larry rutherfor
Any good reason not to use wire mesh as backing for tile. I have a new floor that I am adding too. The new floor has a blue mesh over plywood with quick set. I tried to use cemet board but the 1/4 inch is too thick. I do not have lots of options and can only find the wire mesh. Will I be in trouble useing the wire mesh?
Old 10-23-05, 05:30 PM
T
If you are using the wire lath with thinset, yes, you will be in trouble, it should only be used in full mud jobs or with SLCs over plywood.
