Durock Still Good?
Durock Still Good?
I bought the Durock for my bathroom ceramic tile project about 5-6 weeks ago, but I had some other projects to finish up, so I'm just now getting to it. I completed my new subfloor (3/4" pressure treated plywood screwed and glued to sistered floor joists 16" o.c.), but now I noticed the Durock is a little warped. It has been laying flat on the floor and the sides were warped up (3' x 5' pieces-- 3/8" I think). I turned it over to let it flatten out, and it sounded crackly when I put a slight amount of pressure on the raised middle. The A/C has not been on, so at times it's been very humid in there.
Still OK to use?
Still OK to use?
The Durock will be fine after it is set in a bed of thinset and anchored with galvanized roofing nails or backerboard screws. I think the pressure treated ply is a no-no though. It should be an exterior glue plywood(X) with a BC rating for the plys.
