Underlayments for tile...which one???
I've been reading on this site for the last month or so and seem to be gettin mixed up as to what is for what. Is hardibacker and wonderboard the same thing? And are both meant to underlay tile in a floor application?
When workin on shower areas, isn't durock the underlayment to use? Havin fun, but wanna do it right, and not have to fix it later on...thanks...
Oh yeah, by the way, I'm about to saw/pry up the old mortar bed in the bathroom and was hopin that the new floor would go as such: wood (already there), hardi or wonder, mortar base for levelling, thinset, then tile. I need about an inch build-up from the wood to enable me to tile even with the hallway.
If it ain't broke...fix it!!!
They are all generically called cement boards or CBUs. Some are comprised of different ingredients but they all perform the same after being installed correctly. On the floor 1/4" is predominently used while on the wall 1/2" is the norm. Follow all instructions by the maker.
The plan sounds ok depending on what kind of wood is at the base level. Planking will need a 1/2" sheet of ply over it to isolate the movement that occurs in planks from the tile so they dont crack. You can use a Self Leveling Cement to bring up any low spots. You mix it real loose pour it over the CBU and it seeks it's own level so be careful it doesnt run down a hole or out the doorway
