max size for wall Tile?
What is the recommended tile size for walls around tub/shower area? I wanted to use 13" x 13" porcelain tiles but not sure if this is ok. Please advise
Thanks in advance
Thanks in advance
Thanks for the quick reply twelvepole. So as far as common practice or structurally there should be no problems installing this size tile on walls? Have you personally seen this size used on walls? If so what is your opinion on the look of say a 13 x 13 rather than say a 7 x 7
thanks again
thanks again
