Ceramic on fireplace hearth
I am considering the installation of wall grade ceramic tile on a smooth concrete fireplace hearth.
What types of heat resistant adhesives do the professionals use for fireplace applications?
I have both horizontal and vertical surfaces to cover.
I was told to consider the heavy duty adhesives in the tube for added strength but is that really the best approach?
many thanks
Jake
many thanks
Jake
I am with Daniel. The tube stuff can turn brittle if exposed to heat around the fireplace thus loosing its grip and on a horizontal surface it will leave air pocket voids under the tile due to the ribbon application method which could cause a tile to crack under an extreme point load condition. A modified thinset is absolutely the way to go.
