Tile over Tile
Old 12-29-05, 06:53 PM
thejumpmaster68
Tile over Tile
Can I use an epoxy glue to secure tile over existing tile on a riser in a vertical application?
Background: In removing some old tile that was on the floor, I inadvertantly chipped off some of the tile that was on the riser step leading out of the shower floor that is actually below the level of the bathroom floor. I now need to cover that up with some of the floor tile that I will lay vertically. Any advice?
Thanks,
Will
Old 12-29-05, 10:22 PM
MiTileMan
Sure, that will work fine. You don't even need to used epoxy, thinset mortar would do.
Jaz
