clean grout sealer off ceramic tile
Old 01-12-06, 10:06 AM
I installed ceramic tile on my basement floor. I sealed the grout with a gloss grout sealer. I used a small paintbrush painting the sealer on the grout lines. The problem is the sealer dried on the tile and I can't get it off. When you look at the tiles there is about an inch width of gloss sealer around the edges of each tile. How do I remove the sealer from the surface of the tile? I can't find anything that will break up the sealer to clean it from the tile. Any suggestions?
Old 01-12-06, 10:41 AM
T
Worth a try, might remove some of the sealer on the grout as well, but you can always reapply, this time use a sealer applicator and wipe the tile dry as you go.
http://www.aquamix.com/for_home_use/...8679&pgid=9833
