Cutting 4x4 tumbled marble tile
Old 03-08-06, 10:00 AM
Hello, I am attempting to install tumbled marble tile on my kitchen back splash and was wondering what is the best way to cut around the receptacles is and light switches.
Any info or tips would be appreciated.
Thanks in advanced
Tim
Old 03-08-06, 10:04 AM
wet saw would be the easiest.
Old 03-08-06, 11:31 AM
Thanks for info, How about the 2" tile I plan on using a decorative piece that is going to run down the middle of the wall between the counter and the cabinets it measures 4" x 12 " and is on a mesh backing and it consist of 2" x 2" pieces would you use the same wet saw .
Old 03-08-06, 12:34 PM
Bud Cline's Avatar
Yes.
EDIT:
Well shoot, this program tells me my above message is too short and I need to revise it so here it is.......
Yes Yes Yes Yes!
PITA
Old 03-08-06, 02:28 PM
A wet saw works great on tumbled marble. (Cuts like butter!) I put 4x4 tumbled marble on my kitchen backsplash and it worked great. I was able to cut 45 degree angles on the edge of some of them to use on the ends. I bought a cheap $100 wet saw from HD and it worked well.
Also, be aware that you may have to put extenders on your electrical boxes so that they are safe and don't press in when you plug something in.
Old 03-08-06, 02:42 PM
Uh Oh, extenders, just use longer screws.
Also, good idea to seal it twice before grouting, then everything again a week later.
Old 03-09-06, 04:33 AM
What do you seal the tile with?
Old 03-11-06, 03:39 PM
