regrouting tile--please advise
Old 03-15-06, 09:16 AM
Question regrouting tile--please advise
I tiled my bathroom floor last year, and I picked pretty small floor tiles, so there is lots of grout. The problem is the grout--there is so much of it, and it gets dirty so fast! I did seal it, but I'm thinking perhaps I didn't seal it well enough because the grout still seems gritty and porous. It holds on to dust and dirt like a magnet, and it doesn't help that both the tiles and grout are bright white! Actually, the grout looks more brown now--just terrible! Plus, the grout sits beneath the tile a bit, so it is so hard to even get in there to clean it. I'm hoping I can regrout it, and maybe pick a better sealer. I'm open to any other suggestions too. If regrouting is the best option, how do I prep it for regrouting? Also, can anyone recommend a good sealer? Thanks so much! jeannie
Old 03-15-06, 09:25 AM
V
Depending on Joint size
Depending on the grout joint size you may want to use a NON Sanded grout as opposed to a sanded and there are additives(sealers) that you add to that while mixing that are compatible with post install sealers.
Old 03-15-06, 09:33 AM
response
the grout joint size is 1/8". can I use non-sanded grout? jeannie
Old 03-15-06, 11:48 AM
H
Received 9 Upvotes on 9 Posts
If your willing to regrout then you might want to consider an epoxy grout. These type grouts are more resistant to stains and should be easier to maintain. They are a little more difficult to work with when grouting but will definitly be easisr to maintain. Take a look at this link under products SpectraLOCK.
http://www.laticrete.com/
