Ceramic Over Vinyl?
Old 08-01-06, 05:18 AM
C
Ceramic Over Vinyl?
I have removed the top layer of vinyl and 1/4" luan. Then there is original vinyl attached directly to the 3/4" sub floor. I can remove the vinyl itself without too much trouble but it leaves a paper backing on the subfloor. What should I do before installing cbu? What should I do, leave the vinyl, remove the vinyl, leave the backing paper or shoot myself? Thanks in advance for your advice. Any help ASAP would be appreciated!
Old 08-01-06, 03:53 PM
H
Received 8 Votes on 8 Posts
You need to remove the vinyl and the backing. You can get the backing up by soaking it with very hot water and scraping with a wallpaper scraper.
Old 08-01-06, 07:01 PM
C
Thanks for the info - I'll give it a try
