Tiling fireplace surround
Old 08-15-06, 01:58 PM
Backgound: I'm using 12x12 slate tiles for my fireplace surround.
I need some advice on tiling the vertical legs of my surround. The vertical legs are 27" x 12". Should I use 2 full tiles and a cut 3" tile at the bottom of the legs, or should I cut three 9" tiles? I'm not sure what the standard practice is. Above the vertical legs, I have 5 full tiles going across horizontally, if this is any help.
Thanks for any help.
Old 08-17-06, 05:15 AM
T
You can put the 3" piece at the bottom. Unless you start playing around with mosaics, you don't have any other option.
Old 08-19-06, 10:23 PM
Thanks for the help, I also decided thats the best solution.
