Kitchen backsplash
Kitchen backsplash
The backsplash in my in-laws new home is ceramic tile and the counter is a traditional laminate. Where the two meet behind the sink the grout is very thin and getting wet has made it chip away. Is there anything I can do to stop this from happening? ie. clear caulk or a sealant. I don't know much about tile but hate to see this keep chipping away. I would be afraid to try and match the grout color to repair it.Any help would be much appreciated. Thanks
Use color match caulk any where there is an angle change or a material change. Your situation has both. The vertical wall and horizontal counter top move separately of each other and grout, being non flexible, won't stay there. The tile and counter top have different expansion and contraction rates which produce the same result. The two in concert make it very unlikely the grout will stay in place. Dig the old out and use color match caulk instead of grout to seal the gap between the two. By color match caulk, I'm talking about the corresponding caulk made for every color of grout made.
Use the right caulk
If it's grout, you need the proper grout tool to remove it and to avoid chipping the tile. Caulk is much easier to remove. The big sign for failed caulk is discoloration, mold, looseness, etc.
Do make sure that before you apply new caulk, you clean the area thoroughly, remove ALL old caulk and residue and that the caulk surface is completely dry. Use a high-grade caulk specifically for 'plumbing' purposes. Make sure it completely cures before exposing the areas to any moisture. Even cooking produces moisture. Running water in the sink....
There will be product recommendations on cure time but if you live in a humid climate, it may take longer.
In my experience, cleanliness almost always makes the difference in good original work and a good repairs.
Good luck!
Good luck!
