marble tile question
Old 01-02-07, 06:37 AM
I recently installed marble tile around a corner fireplace and am wondering if I can install just 1 tile on top of the others for a different look. Can this be done and what is the procedure?I have backerboard installed under the first set of tiles.Also can the edges of the tile be polished to look like the front?
How is this done. Thanks in advance for any help
Old 01-03-07, 02:32 PM
Don't understand the top of the other one part, but yes, they can be polished, some of these pads are expensive and you need a grinder, they also make ones you can use by hand, marble is softer than granite and easier to do, I would just take the ones that need polishing to a fabricator, then install them, alot cheaper.
