Cutting Hardibacker
Old 01-25-07, 08:18 AM
W
Received 1 Vote on 1 Post
Cutting Hardibacker
I need to cut out a tub opening in a 1/2" Hardibacker deck. The last time I did this I used a ceramic blade in a jig saw. It was very slow and messy. Is there a better tool for making curved cuts in cement board?
Old 01-25-07, 01:47 PM
H
Received 8 Votes on 8 Posts
Wayne
Hardi recommends that you score the lines and then break the center out with a hammer. The dust from cutting with power tools is hazardous to your health. I know - thats not an exact science.
Ive used carbide blades in my jigsaw, diamond blades on my angle grinder, masonry blades on my circular saw. For a bigger cutouts Id go with the angle grinder. They all work but they are all really messy. Do all your cutting outside and wear a mask and safety goggles.
Woops - just noticed you probably already have the hardi installed and will be cutting it inside. The jigsaw will make less of a mess than the grinder will.
Old 01-25-07, 03:07 PM
W
Thanks for the response. I haven't installed it yet. I was looking for help because I used Hardibacker on a tub deck in my own bathroom and cutting the opening for the tub kicked my butt. I was looking for a better method than the jigsaw.
I'm open for a different product. I bought hardibacker because I've used it for tiling floors and had good luck with it. Of course there were no big cutouts.
Old 01-26-07, 12:29 PM
T
Acually the Roto-Zip bit does work well here, just go slow.
I use an angle grinder and diamond blade.
Old 01-27-07, 03:47 AM
K
After losing badly with a number of weapons, reciprocating saw with course (not wavy) hacksaw blade worked for me. Cuts aggressively and makes large dust. I used a broken old blade - not the one shaped specially for the saw. Throwaway.
