Drilling Thru Onyx Wall To Mount LCD Bracket
Old 01-28-07, 06:41 AM
I have a Onyx tiled wall that I wish to attach an LCD mount, but need to drill thru the Onyx for the mounting screws. What type of drill bit must I use? Any help, suggestions or comments would be appreciated. The sub-base of the wall was was reinforced with 1" plywood to accomodate and support the bracket.
Old 01-28-07, 07:06 AM
mattison's Avatar
Is it real onyx or cultured ? Either way a masonary bit and preferably a hammer drill will go right through it.
Old 01-28-07, 09:58 AM
I've done it that way and I've also used one of those bits that looks like an arrow that's made for glass. That works as well.
Old 01-28-07, 10:12 AM
mango man's Avatar
if you can , drill the grout lines .
I wouldn't use a hammer drill , a regular drill will do just fine and I would be concerned the hammer action could crack or chip the tile.
