Bathroom Floor
Old 03-01-07, 08:17 PM
D
Bathroom Floor
I'm re-modeling a bathroom.
I have discovered that the bathroom floor is made up of what looks like concrete with a ceramic layer on top, the ceramic layer being approximately 0.05 to 0.1" thick. The ceramic layer is textured to look like 1" square tiles.
I think that the concrete is about 0.375" thick and is laid on a sub-floor of plywood.
I have a photograph of it but I don't know how, or whether it is possible, to post it here.
Has anyone ever come across this kind of surfacing before?
If so:-
How do you get it up?
Can you get it up without damaging the plywood sub-floor?
Thanks.
Old 03-02-07, 08:47 AM
H
Received 6 Votes on 6 Posts
I sounds like you are describing 1" mosaic ceramic tile. They generally come on sheets of mesh in 12" x 12" sheets. I'm assuming that because the tile is grouted, you are only seeing the top glazing of the 1" tiles and assume they are somehow bonded to a 3/8" mortar bed. It also sounds like they are bonded directly to the plywood subfloor. If this is not right, you need to explain it better and maybe post a picture. Im not sure how to post pictures here so maybe someone else can help with that.
Old 03-11-07, 04:28 PM
D
Thanks.
Thanks for your help.
I think you guessed right.
Old 03-11-07, 04:40 PM
HotxxxxxxxOKC's Avatar
It may also be etched concrete. They can etch and stain concrete to look almost exactly like tile. Just a thought.
