Ceramic Tile on Concrete Floor
Old 04-02-07, 08:04 PM
D
I would like to install ceramic tile on a concrete floor in my basement.
The floor has been painted, (with latex floor paint) and I am aware that the paint should be removed before laying tile.
My problem is what to do with he expansion joint running through the area I want to tile.
The joint is 1/2 to 3/4 inches wide. Do I fill this or lay some kind of membrane down first before tiling.
The floor is stable and has not cracked or moved in the last 15 years.
WHAT TO DO?
Old 04-03-07, 04:27 PM
H
Received 7 Votes on 7 Posts
You need to design your tile layout so that a grout joint will line up over the control joint. Caulk this tile joint with a color matched caulk that matches the grout color.
Its a good idea to use an isolation membrane like Schluter's ditra over the entiere concrete slab as added insurance for any future movement in the slab.
Old 04-04-07, 06:48 AM
Having no experience with ditra, this comes from a somewhat ignorant position, but wouldn't a well installed coat of redgard do the same thing?
Old 04-04-07, 02:38 PM
HotxxxxxxxOKC's Avatar
I think Redgard would be the way to go as well. Ditra can be a pain in the .......
Old 04-04-07, 03:04 PM
H
Redgard may be fine here. My preference would be the ditra though.
