spacers
Old 05-12-07, 05:13 PM
spacers
I am about to lay 12 inch porcelean tile tommorow. I bought 1/4 6mm tile spacers. Is this the correct spacers for 12inch tile?
Old 05-12-07, 05:24 PM
"correct" is a relative term with spacers. They help determine the size of your grout joints and, if you want 1/4 inch grout joints, then, yes, they're correct. My personal preference for less experienced installers is 1/4 inch spacing because they tend to be a bit more forgiving and make it easier to hide imperfections in tile sizes or installation.
Old 05-12-07, 09:39 PM
Smile
Which ones did you get, the ones that look like x's or the orange ones from Lowes. I just got done doin mine with Porceline and I will tell you the orange ones were easier to use as you can use them in the corners. The orange ones are 1/4" and are double sided with a straight line on one and an + on the other side. Hope this helps out a bit. Cheers Brian.
