Tips, Tricks, or Suggestions: Tile on Concrete Removal
Old 08-07-07, 12:00 PM
I am removing tiles from concrete slab.
Most rooms went as expected. Using a 4' pneumatic scraper the tile and thinset came up with moderate effort.
The problem is the mastert bath. It was put down with a white thinset and I am literally having to pulverize it to remove it. Between the dust and damage to the slab that will occur, I thought I should see if anyone had any tips.
As it stands, it seems I will need to continue pulverizing it and then refinish the slab.
(I am removing the tile to put down hardwood)
Thanks for reading.
Old 08-07-07, 04:06 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Hilti makes an incredible hammer drill that will make small order out of your tile. It is a hammer first, drill second and can be rented from the box stores. Get a wide hammer bit and go to town.
Old 08-08-07, 09:36 AM
Great suggestion. I will have to try it. Thanks cizzi!
