sanded vs unsanded grout
Old 11-18-07, 08:16 AM
B
I just installed a travertine tile backsplash w/3/16" spacers. I was gonna grout w/ sanded grout, but decided to use some glass accent tiles. Do i have to worry about scratching the glass with sanded or should i just use unsanded.
Also, does the tile need to be sealed prior to grouting?
Old 11-18-07, 09:03 AM
HotxxxxxxxOKC's Avatar
You only need sanded grout for grout joints 1/4" and bigger so you need non sanded.
The travertine does need to be sealed. The only tile that does not need sealing is porcelin and ceramic.
Old 11-18-07, 09:12 AM
T
Any joint over 1/8" needs sanded grout, it can also be used with an 1/8" joint.
The travertine stone if cut correctly from the manufacturer should have been spaced 1/32 to 1/16" and then unsanded used.
As for the glass tile, test it by rubbing some plain sand on it and see if it scratches, should be fine though.
Old 11-18-07, 09:14 AM
Good catch! My brain is non functioning this morning!
Old 12-12-07, 11:17 AM
G
[QUOTE=Tileman;1261128]Any joint over 1/8" needs sanded grout, it can also be used with an 1/8" joint. QUOTE]
I'm tiling a wall with 1/8" joint (6"X6" tile). Since I can go either way, which is better? What are the advantages and disadvantages of each?
Thanks
Old 12-12-07, 12:24 PM
H
Received 8 Votes on 8 Posts
G
With porcelain you can use either on 1/8" joints. The non sanded will have a smother look to it and the sanded will have a little textured look. Any bigger than 1/8" joints with the non sanded and it tends to shrink and crack. The sanded wont shrink. My preference for 1/8" is sanded but either will work.
