Evening newly exposed tile edge
Old 11-26-07, 07:18 PM
I recently removed some carpet that butted against tile. I am replacing the carpet with tile and where the new tile meets the old tile, the old tile edge is uneven- because it was hidden by the previous carpet edge. How can I even up the edge of the pre-existing tile, while it remains on the floor, so that it looks good against the new tile? I tried a dremel tool without much luck...
Old 11-26-07, 07:32 PM
HotxxxxxxxOKC's Avatar
You should install a T moulding for these transitions.
Old 01-05-08, 07:04 PM
Thanks for the advice, but I went a different route. I purchased an angle grinder with a tile blade and, using a metal T-square, cut the tile and created a straight edge. worked great.
