Morter bed on sub floor.
Old 12-16-07, 07:50 AM
W
I am setting a solid surface shower stall base in a bed of morter.
Do I need to put down tar paper or plastic, covering the sub floor first?
Old 12-19-07, 09:29 AM
T
Won't hurt. It will prevent the subfloor from absorbing moisture out of the bedding material so that it may cure with the proper hydration. Next person to replace that tub or shower pan will be thankful to you as well.
