Remove Dried Ceramic Tile Adhesive
Old 12-18-07, 11:09 AM
D
After Tiling The Wall Around The Bathtub, I Found Some Patches Of The Adhesive In The Tub. My Question Is - How Do I Get The Adhesive Off The Porcelan Without Scratching It? Thanks!
Old 12-18-07, 04:58 PM
HotxxxxxxxOKC's Avatar
Only thing I can recommend is getting a putty knife and wrap a thin cloth around it and start trying to tap the thinset off, carefully.
There are no miracle type chemicals to removing thinset.
I will move this thread to the tiling section to get more attention and input.
Old 12-19-07, 06:27 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Dried adhesive
Hi Don
Hmm, could it be that you have mastic , not thinset? You did say adhesive, which to me is glue= mastic?
If it's mastic, acetone should take it off just fine. Use a soft cloth wet with acetone, hold it on the mastic patches, then rub lightly, turning cloth to a clean area often.
If its thinset, then Hot is right. I've heard of people using muriatic acid, but sure wouldn't be my first choice. That stuff is for pools IMO.
Good luck
Old 12-19-07, 09:04 AM
T
I've never needed anything more intense than a plastic scraper or a straight edge followed by a white scrubbie, for either thinset or mastic. They key is to get on it immediately.
Old 12-19-07, 02:42 PM
Bud Cline's Avatar
This place never changes!
Don in either case use some warm water to soak the adhesive then it will scrape away easily with a plastic windshield ice scraper or a razor blade scraper. Plug the tub and fill it (if the water will cover the adhesive). Let it sit for an hour or so then go after the adhesive with a scraper.
Old 12-19-07, 04:14 PM
Gunguy45's Avatar
Super Moderator
Dried adhesive
Hey Bud Cline
Just tryin to learn here. Water will take off mastic? Or i should say soften it enough to allow it to be easily scraped? Is that because its an enameled steel tub or does that matter? I just thought because the mastic I've used is solvent based I needed a solvent. I know alcohol didn't work worth anything.
Thanks in advance for the knowledge.
Best in 2008
Old 12-20-07, 04:37 AM
T
LOL Bud, your not kidding. Welcome back.
Old 12-21-07, 02:46 PM
D
Thumbs up remove dried ceramic tile adhesive
Bud - thanks for the info. I did as you sugested, it took a lot of "elbow grease" but it is gone. Thanks again.
Don
