grout removal??
grout removal??
What is the best way to remove grout between tile and the top edge of a bathtub? I ask because I need to caulk that seam, but the caulk doesn't seem to want to stick to the grout. Any suggestions would be helpful.
Also, products to clean grout to make it look new again??
Thanks,
Thanks,
Small hand held grout saws are available at Home Centers for around five bucks, that's probably the easiest way to do it if it's grout. If it's caulk then a utility knife works good.
