Ditra and subfloor
Old 03-01-08, 12:10 PM
N
Ditra and subfloor
After ripping up my vinyl flooring - there is the paper residue stuff left over - it is not coming up easily!
Can I ditra over that, or should i put more wood down. I do have some self leveling cement stuff that i will be putting down in spots - should I 'skim coat' the whole floor?
Thanks
G[IMG]<img src="http://img225.imageshack.us/img225/8688/p2170044hn6.jpg" alt="Image Hosted by ImageShack.us"/><br/>Shot with <a target="_new" href="http://profile.imageshack.us/camerabuy.php?model=SP510UZ&make=OLYMPUS+IMAGING+CORP">SP510UZ</a> at 2008-03-01[/IMG]
Old 03-01-08, 01:44 PM
Bud Cline's Avatar
You cannot use true Self Levelling Compound in just "spots", floor patch yes SLC no.
The remaining product is basically a "paper-like felt" type product and some warm water soaking should help you to scrape it up.
DITRA must be firmly attached to the substrate and going over what I see there isn't going to be recommended.
What you have is typical.
Old 03-01-08, 02:01 PM
N
I think i have some floor patch around here too! I might just go with cement backer board instead of trying to get that stuff up (tried water and heat gun.... ) more plywood + ditra might make the transition a bit too much.
Is ditra really that superior to Cement backerboards? All I hear is how wonderful ditra is - but is the cement stuff 'just as good'?
Thanks
G
