How to cut Schluter Tile Edge?
Closed Thread
Old 04-05-08, 08:51 PM
C
I'm going to be using the Schluter®-JOLLY for the first time in a tile application. What tool should I use to cut a 45 degree angle for the corners?
Old 04-06-08, 10:00 AM
Bud Cline's Avatar
I use my power miter saw for 45's on all Schluter edging. Straight cuts are done with a hack saw. I suppose you could use a hacksaw to make the 45's if you were to use a mitre box.
Old 04-06-08, 07:21 PM
C
I tried my miter saw but had some difficulty with some of the cuts. Either the steel would warp, the blade would jamb, or a combination of the two.
How do you position the "L" in the guide on the saw?
Old 04-06-08, 07:51 PM
HotxxxxxxxOKC's Avatar
What blade are you using for your saw?
Old 04-07-08, 09:19 PM
C
Cheap 10" blade that came with the Husky...
Old 04-08-08, 02:53 PM
You are trying to cut metal with a wood blade? I can see the problem now....
Old 04-08-08, 05:33 PM
C
Seemed thin enough that I could get away with it.
Old 03-20-13, 07:28 AM
How I cut my Schluter Profile pieces
We use our mini chop saw with a non ferrous blade (for cutting metal with no steel content). I have a 10" Chop Saw for this.
The real key is keeping the right side down on the chop saw. You should not have the face of the profile against the chop saw. The bottom needs to stay tight to the base. Often we use scrap bits of wood to hold it still or use them at the back to prrevent any blow out when cutting.
If you cut the profile with the face against the chop saw you can get a messed up angle.
I have a install picture example on my Houzz account. I also have many pictures loaded on my Photo Bucket Account
I have
Old 03-20-13, 07:30 AM
Received 94 Votes on 83 Posts
Welcome to the forums, John. You're replying to a five year old question.
Closed Thread
