Removing grout hazing
Old 05-10-08, 06:48 AM
W
I have hazing on my shower floor. The shower is fiberglass and the hazing is coming from the grout. All we use on the tile is either Lysol Soap Scum remover or Lysol Mildew remover. Nothing will remove it. I tried "Grout Haze Remover" by 4Care and although it worked slightly, it just comes right back. I had tried Magic Eraser but that, too, only slightly removed the haze. Any help for me?? Thanks.
Any suggestions would be helpful. If it can't be removed what advice would you give to redo it in some way?
Old 05-10-08, 07:45 AM
HotxxxxxxxOKC's Avatar
Try 50% WHITE vinager and 50% water. If that doesn't work, step up the vinager.
Old 05-10-08, 12:44 PM
H
Received 9 Votes on 9 Posts
Something doesnt sound right here. What kinda grout do you have that your getting grout haze from the walls on the fiberglass pan. This makes no sense. Are you sure its not soap scum, hard water stains or something else?
Old 05-10-08, 12:58 PM
Johnny, you haven't seen fiberglass tiles with grout?
I just thought part about the fiberglass tub was bunk, and assumed they have a tiled wall....... hopefully they can clarify.
