Slate tile over cement basement floor
Old 05-13-08, 09:21 AM
Hello all
I am in the process of trying to install 12x12 slate tile in an area 12'x13'. The floor is concrete with a few hairline cracks and it slopes down about 1/2" in the middle of the floor, This slope spans the entire length of the area. I am assuming it was for water drainage because it leads to a drain in another area. The slope is gradual down to the 1/2" then back up in around 6'. I need to know if I would need to level this and what should I use to do so. The concrete will soak up water so I'm pretty sure there isnt any kind of sealer on it. It is smoot but not glossy smooth. What would I need to do to get the floor ready for the laying of the tile? Thanks in advance.
Old 05-13-08, 02:14 PM
T
Received 68 Votes on 64 Posts
I just did my slate 6x6 on bare concrete floor. It needed some 1/2 inch to near 1 inch make up using mortar mix. We used thinset on top of the uncured mortar mix. So far, so good.
Old 05-14-08, 01:25 PM
H
Received 9 Votes on 9 Posts
Duplicate post
http://forum.doityourself.com/showthread.php?t=345344
This forum requires that you wait 180 seconds between posts. Please try again in 24 seconds.
Darn this thing got me again.
