Bonding tile to tile
Old 06-02-08, 01:15 PM
B
Just a quick question about applying thin set over tile to adhere trim tile. Will the thin set grab on the tile (which is fairly smooth) to hold the trim tile that I'm putting around a glass block window that is in the shower area.
Is there some kind of primer to help with this sort of thing or can I simply scuff the tile a little.
Thank You
Old 06-02-08, 02:01 PM
Bud Cline's Avatar
Scuff the sub-tile first.
Use a modified thinset that is made for tile on tile applications.
Old 06-02-08, 02:24 PM
B
tile on tile
Thanks Bud for the quick reply. Now where can I obtain this type of thinset mortar? Do the big box stores have them?
Thanks
Old 06-02-08, 02:28 PM
Bud Cline's Avatar
Yes. Use the high end product they have available, just depends on where you go. Trouble is...it's mostly all in fifty pound bags.
Old 06-02-08, 02:38 PM
B
tile on tile
Thanks again! I sure don't need 50Lbs of thinset. Are there any other options?
Old 06-02-08, 03:32 PM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
No. No other options.
Old 06-02-08, 03:38 PM
Bud Cline's Avatar
You can probably find a real tile store that will sell you a few pounds of modified thinset.
Ace Hardware sells some of the thinset products in 10# box I think.
Old 06-06-08, 02:23 AM
B
tile on tile
I went to loew's and found a thinset that states on the bag can be used for tile on tile situations. Comes in 25lb bag.
Mixed up a batch and put up the trim. Holding real well.
Thanks again for your help Bud.
