Why is my bathroom tile so high?
I'm in the process of installing bamboo flooring in my master bedroom (5/8" planks). My master bathroom is 'OE' tile and after pulling out the carpet I noticed that that the height difference is approximately 2 1/4"!!! Is this typical? The existing marble threshold was build-up with what appeared to be almost 2" of concrete. This obviously isn't a good practice since the threshold has been cracked in half ever since I bought the house in 2001. So the question is - how do I do it right? Stack two or three marble thresholds using mastic and make it even with the bathroom floor? I'm open to ideas...
--Rob in DC
--Rob in DC
Is this typical?
...how do I do it right?
...how do I do it right? Stack two or three marble thresholds using mastic and make it even with the bathroom floor?
You should also consider adding a layer of plywood to reduce the difference. A beveled or ramped marble threshold will also help. Do not stack thresholds.
That's the way floors used to be done, I ran into a bath floor with 3.5" of deck mud in a second story built in the '30's. Looks like 4.25" wall tile on that floor?
Jaz
Jaz
Yup, sure is. Is this also the "ol' fashion" way of doing bathroom floors?
Thanks for the input guys. Eventually I'm gonna get to the bathroom floor and replace it with some decent natural 12x12 tile. (Travertine perhaps) This means that getting the original tile out is going to be a major PITA...
PS. house was built in 1993...
Just so happens I am duplicating such a thing in a new renovation next week. The customer wants that look from that period - so be it!
