Gray or white, Whats the difference??
Old 10-05-08, 08:43 AM
Question Gray or white, Whats the difference??
Greetings... Ready to Start laying 13" by 13" tile on my bathroom's concrete floor... What is the difference in the white and the gray mortar?? Is HD's versabond gray motar that you add only water and mix OK for the job??? Thanks !!!!
Old 10-05-08, 09:04 AM
Received 2 Votes on 2 Posts
Nothing more than color. If you will be using a light colored grout, then choose the white thinset. Darker color grout you can use the gray. With some natural stone tile, white is a better choice.
Don't know. You gotta give us a little more info. Are you using a sheet membrane over the slab, or setting direct to the slab? What kinda tile, ceramic/porcelain or stone? What kinda conditon is the slab in, any cracks, is it free of paint, sealers etc.? Is this a new concrete slab?
Old 10-05-08, 10:05 AM
Thanks ....
I am using a porcelain tile with a textured stone like finish on the tile. (not slick) I scraped and cleaned up old vinyl off the floor. Will be applying directy to concrete floor. No cracks , concrete in good shape. Thanks !!!
Old 10-05-08, 11:26 AM
HotxxxxxxxOKC's Avatar
Versabond will be perfect.
Old 10-05-08, 03:27 PM
Thanks!!!
Thanks for your help !!!!!!!!!!!!!!
Old 10-06-08, 09:17 AM
You can probably get by with versabond. Versabond is Custom Building Products low end modified thinset. I'd not use it with porcelain, but hey thats just me. I'd use a better quality modified thinset here.
Old 10-23-08, 10:16 PM
spend the extra money on the flex bond if you want to stick with custom building products
