Concrete Floor, Black, Polished and Epoxy. Too Hard?
Old 01-15-09, 11:44 AM
C
First of all, nice to meet you all!
Needs:
I have a store I want to re-model and I wanted to add a Black, Concrete Floor. I was reading some articles and after a while I knew I wanted it polished with a epoxy finish.
Here is a pic how I want it:
Background:
The store already has a concrete floor, but it is cracked and in really had shape, I wanted to remove about 1 1/2 inchs and pour new concrete.
I have worked with concreate before, but only as sub-floor.
I'm a really good handyman btw
Questions:
1.) Is this job too hard for a DIY job?
2.) Removing 1 1/2 inches of concrete is too little?
3.) How do I make the concrete black?
4.) Is applaying the epoxy too dangerous?
Thanks for your time!
Old 01-15-09, 03:10 PM
HotxxxxxxxOKC's Avatar
Welcome to the forums!
I'm gonna move this thread to our "concrete" section. We got some good guys over there that should be able to give you answers.
Old 01-15-09, 05:12 PM
C
Thank you!
Old 02-07-09, 07:21 AM
B
DIY Epoxy
Too answer your question on how to make the concrete black, the answer is... you don't. You're going to cover the concrete with black epoxy, and then put a coat of urethane on top of that. The urethane will help protect your finish and give you a nice glossy look. I did my basement and garage and wrote up all the details at A lot of Fall Projects! though you can skip the part about broadcast flakes. You may want to use a non-skid additive to yours though, otherwise that slick surface may be too slick, and your customers might slip.
hope this helps,
Dave
