Subflooring Questionable
Old 01-25-09, 07:28 PM
I think tiling is a non-starter with this floor?
I was considering tiling the kitchen and dining room but I’m not so sure the subfloor is good enough.
The joists are 9.5” I-Beam ( if that is what you call it ) with a span between joists of 32”
The joist supports are 10’ apart.
There is a 1 1/8” tongue and grove over the joists.
Are these joists too far apart to consider tiling even if additional plywood is added?
Thanks
Old 01-26-09, 12:30 PM
HotxxxxxxxOKC's Avatar
Think we would need a engineer to figure out your deflection with those I-beam's. You will probably need the manufacturer name (should be printed on them). 32" is pretty wide for a standard joist spacing, so not sure about I-beam.
Old 01-26-09, 01:03 PM
H
Received 9 Votes on 9 Posts
I'm not aware of any isolation membranes or cement board that are ok for 32" oc spacing. Maybe vinyl or carpet is a better choice here.
Old 01-27-09, 06:09 PM
Thanks
Thanks guys,
I will stay with something lite this time.
