Basement bathroom
Old 02-04-09, 11:33 AM
C
Basement bathroom
Hello...
I am planning on tiling my basement bathroom. Also, want to heat the floor as well.
Here is my question: Since the rest of my basement has a dricore subfloor under the carpet, I want to build up my tile floor so I don't have too much of a height transition between the tiles and carpet. Can I lay down 3/4" plywood or cement board or something else like that so my tiles are close to the same height?
Any ideas would be much appreciated!
Thanks, Craig.
Old 02-05-09, 08:47 AM
H
Received 6 Votes on 6 Posts
A bonded mudbed would be the way to go here. If the area is small, you could also use a self leveling compound here as well. The cheaper solution will be the bonded mudbed. Plywood and cement board wont work here.
Old 02-05-09, 12:43 PM
C
Ouch was hoping for something easier! Since this is the only room where I need to raise the floor a bit - would it make sense to stud the walls first then lay the new cement within the new studwalls?
Could I install the tub before the floor too? That would end up having the floor lower under the tub....
Thanks...
