Hardibacker board
Old 06-06-09, 07:21 AM
Hardibacker board
When I apply the Backer board to the floor it says to apply 1/4 in thin set.Can I use the glue for the titles (on bottom of the backer board) or go out and buy the thin set and mix it.
Old 06-06-09, 07:35 AM
HotxxxxxxxOKC's Avatar
Buy the thinset and mix it. The thinset is not there to secure the board to the subfloor, it's there to support the board and fill voids.
Old 06-06-09, 10:50 AM
chandler's Avatar
Received 3 Votes on 3 Posts
I agree. You are going to buy thinset for the tiles anyway.
Old 06-08-09, 09:09 AM
Received 4 Votes on 4 Posts
What glue are you talking about? You should be using thinset to set the tile as well. No glue.
Old 06-08-09, 04:03 PM
The same ceramic tile thinset mortar that is used to install the tiles can be used to install the backboard. If you want...the less expensive unmodified (dryset) thinset can be used for the backer board but the more costly modified thinset is usually used for the tile.
I doubt the instructions say to apply a 1/4" of thinset exactly, that's too much. What you do is use a 1/4" notched and spaced thinset trowel. This tool will apply the correct amount in the required thickness. Yes it will be 1/4" while at the same time you will be making grooves in the fresh thinset. Once the boards are in place the thinset isn't really 1/4" thick.
