Rounding over slate tile edge?
Old 07-13-09, 08:30 AM
Our subfloor and finished wood floor are the same height. So, with the slate in the kitchen, where the tile abuts the wood floor, there will be a height difference. I have bullnose tiles for the edge, but neither the wife nor I like them since they're all the same size and don't match the size and shape of the rest of the slate.....
I have a router table and heavy-duty router. Can I use a rounding-over bit and put my own rounded edge on the slate or does this have to be done with water like a wet saw? I've only got to cut about 10 feet of rounded edges, so if it eats a router bit or 2 that's ok, as long as I can get really good results...
OR, am I better using one of the strips - preferrably wood to make the transition between the stone and the wood floor?
Old 07-13-09, 09:13 AM
Received 25 Votes on 23 Posts
Any regular router bit wouldn't handle it. A diamond faced bit would, but they are pricey. Just search on Diamond Router Bits.
Here is just one:
Q4 Diamond Router Bits :: Concrete Countertop Specialties
If you want to freehand it, there are diamond faced blades and cups that would do the job.
Bud
Old 07-13-09, 08:04 PM
Yee gads, that IS pricey for cutting a half dozen tiles.......
OK, maybe better using some kind of transition strip...
I drilled holes in the slate using a regular hole saw - didn't even dull the thing, so I figured surely a carbide bit on a router should be able to do the job... I may try it anyway on a scrap piece just to see what happens...
