Uneven concrete floor
Old 07-20-09, 07:08 PM
A
I am trying to lay tile on an interior basement concrete floor on the lower level of my home. While preparing I noticed that the floor is uneven. Using a laser level, I've found that the lowest point is 7/8" lower than the highest point. What is the best way to even out the floor before I begin tiling.
Old 07-20-09, 10:03 PM
Received 1 Upvote on 1 Post
I am very glad your basement floor is made of concrete, is inside and in the lower part of your house.
A tiled floor does NOT have to be level.....just as flat as possible. The spec is generally; "flat within 1/4" in 10 ft. and 1/16" in 12" of the required plane".
If the floor goes up and down, there are many floor patching products around. Be should it's a Portland based product and read all the directions.
Jaz
