Re-using cement board
Old 08-18-09, 07:21 PM
I plan on taking up old ceramic tile and linoleum and replacing with new ceramic. Can the old cement board underlay be saved, or will I need to replace it?
Old 08-18-09, 07:27 PM
You will know when you take up the tile, if you can reuse it or not. Depending on the damage incurred while removeing said tile.
If it's a clean undamaged cement board..your good to go
Old 08-19-09, 06:19 AM
Thanks, actually now that I have started taking up the old tile, it is 1/4 inch plywood underlay, not cement board. Should I replace this with cement board, or is plywood acceptable?
Old 08-19-09, 11:16 PM
Some types of plywood are acceptable but not recommended by any tile setter pro I know. Your 1/4" ply is probably luaun which is often used under vinyl but is NOT suitable anywhere in a tile installation. Take it to the curb.
Remove it, hammer down the staples, then re-screw the entire floor. Spread thin set mortar under your new 1/4" tile backer, fasten per directions and tape all seams etc. If you wanna step it up a notch you could install Ditra instead of the CBU.
Jaz
