Do I put Caulking around Tile?
Old 08-26-09, 08:16 AM
From waht i understand, I don't tile to the wall. I leave 1/8 of an inch space between the tile and the wall. But to prevent water from getting under the tile, i need to put caulk in the gap. What type of caulk do i use? Any kind?
Thanks!
Old 08-26-09, 04:46 PM
Thanks!
You need to use sanded caulk. Something close to your grout color. Homer has a few choices that are the same color as their polyblend grout.
Old 08-27-09, 12:01 PM
Thanks very much! I'll probably talk to the company I bought the materials from and get the caulk. That's probably more expensive though i guess.
Does caulking the grooves between the wall and the tile require any type of expertise? is there something i need to keep in mind when i do it? Do i fill it up to be level with the floor?
I ended up getting rid of my tile guy after he finished tiling the floor. He was a relative and was causing me problems--plus not doing work. This is one of the only things i still need to do in this room.
I still have 2 other rooms though to tile so I may be back. lol.
Thanks!
Old 08-27-09, 02:14 PM
HotxxxxxxxOKC's Avatar
What? Is this in a shower, bath floor, what? If it's just a bathroom floor, you don't need to caulk the perimeter near the wall. Base moulding covers this. Also, grout and the tile are not waterproof anyways.
Old 08-27-09, 02:33 PM
You know i was thinking about the hallway in front of the bathroom. but you know, stupid me, it does include my master bathroom.
But yes, it is the bathroom floor--not the shower.
I heard that if i allow water to get underneath it could cause damage so i needed to fill the gaps with something to prevent water from filling the spaces.
i'm going to look into this further because if i don't need to do anything else that would make life easier but i don't want to spend a lot of money and ruin something either.
You are saying i don't need this right?
Old 08-27-09, 03:15 PM
No need to do anything. Good to go.
Old 08-27-09, 03:30 PM
I thought you were talking about the walls in your shower...sorry.
Floor is GTG... Baseboard or quarteround is all you need. Need to leave that 1/8 " for expansion. I would use it on your floor where your tile meets your tub or shower...especially if its one of those plactic inserts.
Old 08-28-09, 06:06 AM
Thanks guys! Fantastic!
Wow. i must lengthen this message to 25 characters. I hope this worked. Jezzz!
